I use K8055D_C.h and the dll found in k8055_vc2005.zip.
In my code I use OutputAnalogChannel function, for DC voltage output,
all is working good with 1 K8055 connected, however with 2 K8055, the outputs voltage of each boards are in strange ranges, the red led of the 2nd board blink very fast …
I tried to add some delays, but …
do CloseDevice only at the end, and not each time.
I can’t find my answers in the dll doc and in the forum.
Maybe, I should try the last Dll in k8055dll_rev3_0_2.zip, but I tried so many things …
Test with XP SP3, 32 bits
Dev IDE : QTCreator
Also another question, can we run two K8055 on the same address ? (same Sk5 and SK6) cause they are doing the same thing.
[code]void MainWindow::convertisseur(double val1, double val2)
QString styleRouge(“color:#C00000”);
QString styleVert(“color:#008000”);
if(OpenDevice(0)==0)
ui->K_status->setText("K8055 board 0 OK");
ui->K_status->setStyleSheet(styleVert);
else
ui->K_status->setText("K8055 board 0 open error");
ui->K_status->setStyleSheet(styleRouge);
if(OpenDevice(1)==1)
{ ui->K_status1->setText("K8055 board 1 OK");
ui->K_status1->setStyleSheet(styleVert);
else
{ ui->K_status1->setText("K8055 board 1 open error");
ui->K_status1->setStyleSheet(styleRouge);
if(val1<0)
{ val1 = val1 * (-1);
val1 = val1 / loc;
val1 = val1 * 51;
OutputAnalogChannel(2,(long)val1);
OutputAnalogChannel(1,0);// - negative of HSI
else
val1 = val1 / loc;
val1 = val1 * 51;
OutputAnalogChannel(1,(long)val1); // + positive of HSI
OutputAnalogChannel(2,0);
CloseDevice();
if(val2<0)
val2 = val2 * (-1);
val2 = val2 / glide;
val2 = val2 * 51;
OutputAnalogChannel(2,(long)val2);
else
val2 = val2 * 51;
OutputAnalogChannel(1,(long)val2); // + positive of HSI
[/code]
