K8055 Linux Source Code
Years back (2007) I got this source code off a Vellman K8055 thread.
It’s been modified to read and write to text files called input.txt and output.txt.
http://n1ety.com/K8055/cue.tar.gz
You’ll need to download and install libUSB-devel before you run ./configure
The executable resides in src dir after compile, called cueib.
Copy cueib, input.txt, and output.txt to a seperate DIR and run.
Use a bash or whatever script to read and write to from input.txt and output.txt.
Could I be lucky you could post a new link to the file?
