Hi Community!
I’ve coded a new linux kernel module/driver for the velleman’s K8055 board.
-> http://sourceforge.net/projects/velleman-k8055/
I also work on a perl module which provides an interface to the K8055 driver.
For further information take a look at the drivers source code (k8055.[ch]{1}).
You can also play with the ‘velleman-userspace-testapp’ (you will find it at the drivers project site)
or just write your own code
NOTE: I’ve tested the driver under 2.6.x kernels and under only ONE board.
Don’t forget to unload the usbhid driver before inserting the k8055.ko module.
Feedback is welcome.
Greetz
Manuel Gebele
