I want to use the K2032 as a 5V dvm. (as output for the K8055), can this be done?
At the moment i get an error when i set a value above 64. (test it online: see signature link and choose card1)
Grtz
Grtz
The K2032 should be capable of measuring the K8055 DC output.
What ‘error’ do you get ?
‘EEE’ overflow i think.
I thougt it was a -99 to 999 mV meter. but i’m not sure. But how can i modify it to 0 to 5V meter?
It is just a matter of dividing the 0…5V output of the K8055 with a resistor divider. Connect two outer pins of 10K trim pot between output of the K8055 analog out and GND. Set K8055 output to 5V dc. Adjust trimmer until you measure 1V between GND and center pin. Connect center pin of trimmer and GND to K2032.
That was easy :), now i can put the card output value to the K2032.
Thx 417
