K8055 for Windows 64bit OS's?
Hello all (again)
Are there drivers for Vista64bit or XP64bit for the K8055?
Current K8055D.dll is 32bit only.
Bart
BTW, a Velleman package (K8055_DLL2) contains K8055D_C.dll; what is the difference with K8055D.dll?
(using depends i noticed the same method, but they are mangled)
The DLL2 is a newer version than the original. the DLL2 is more compatible with more compilers, also C compilers, and can be used with XP64.
The drivers are NOT compatible with Vista64.
At this moment the DLL runs fine under windows 7 rc 64 using visual basic 6.0.
Although it is’nt a 64 bits driver you can use it.
Greetings HOB
