My K8055 kit seems to work well in all ways but one.
digital input 2 is always on.
I suspect a short somewhere, or a defect IC.
it does not look like a short after IC2 to me because:
I have compared the voltages (and voltage changes) from IC2 pin2 to the other digital input pins on this IC, and it seems that pushing the di2 button gives the same change in voltage on pin2 as pushing any other button does on the relevant pins on IC2.
After reading some topics here I tried to swap IC2/IC4, but the results were the same, so I suspect that IC4 and IC2 work fine
all of the outputs of IC2 (pins 14-18) behave like they should.
When all digital inputs should be off, comparing voltages over in/out on IC2 and in on IC3 for di1 to di2:
The voltage over IC3 pin7 (0V) << IC3 pin6 when both should be the same (no input, voltage high). The outputs from IC2 for di1 and di2 (pins 18 and 17 respectively) are the same (high).
Can you help me, what went wrong?
thanks
