Regarding K8055-1 pulse counter on Input 1 and Input 2
If I set the debounce to 0ms, what is the maximum frequency that can be counted ?
The counters can count pulses up to 2kHz if the duty cycle is 50%.
Thanks,
Sounds like you are not using the hardware timer.
It would be usefult to be able to measure higher frequency and also measure period
If you use the hardware timer it could be much faster
Regards
