Hi there i’ve got a K8055 card but am having trouble connecting it to my computer, I’m running vista64, when I plug in the device LED8 flashes 3 times and then goes off as its supposed to, however when I try and run the demo the card is not found, I have copied the DLL files to both my system32 file and SysWOW64 file and have got a screenshot of the card plugged in, just wondering if anybody knew the problem? The card has worked before this when I first constructed and tested it with the demo project in uni.
Can you test the card in other PC ?
It seems that wrong data is read from the K8055 microcontroller.
The “Current Config Value” should be: 0x01.
You can return your unit for inspection/repair.
