K8055 Board issue in saving analogue input values into *.txt
How can I save analogue input values as *.TXT (not for bar-graph indication)? I bought K8055 board and I want to get analogue input values in Visual Basic 2008 program.
Thank you,
Mark
You can save the values for example in the following way:
In the examples folder go to K8055NDemoVB_2008 and open the K8055Demo project.
Add these two lines to the declarations section: Dim file As System.IO.StreamWriter Dim counter As IntegerIn the Button1_Click procedure change:If h >= 0 Then Timer1.Enabled = Trueto If h >= 0 Then Timer1.Enabled = True file = My.Computer.FileSystem.OpenTextFileWriter("test.txt", True) End If
Change the Sub Timer1_Tick to look like this: Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick Dim i As Integer Dim Data1 As Integer Dim Data2 As Integer Timer1.Enabled = False i = ReadAllDigital CheckBox4.Checked = i And 1 CheckBox5.Checked = (i >> 1) And 1 CheckBox6.Checked = (i >> 2) And 1 CheckBox7.Checked = (i >> 3) And 1 CheckBox8.Checked = (i >> 4) And 1 ReadAllAnalog(Data1, Data2) VScrollBar3.Value = 255 - Data1 VScrollBar4.Value = 255 - Data2 Label6.Text = CStr(Data1) Label7.Text = CStr(Data2) counter = counter + 1 If counter < 10 Then file.WriteLine(Label6.Text + " " + Label7.Text) End If If counter = 10 Then file.Close() End If TextBox1.Text = CStr(ReadCounter(1)) TextBox2.Text = CStr(ReadCounter(2)) Timer1.Enabled = True End Sub
The added code section is: counter = counter + 1 If counter < 10 Then file.WriteLine(Label6.Text + " " + Label7.Text) End If If counter = 10 Then file.Close() End If
Now the first 10 analogue input values are saved to file test.txt.
The file is located in the folder \K8055Demo\bin\x86\Debug
How much time is it between two acquisition analogue input values, roughly? How to calculate the time gap between 2 saved analogue input value?
Thank you,
Mark
In the K8055Demo program the timer (Timer1) interval is 50ms.
So the time cap between the samples in this case is 50ms.
Thank you, sir. Your reply is very helpful. By the way, can we change the time gap (1ms, for example) between the sampling input analogue signals?
Thank you,
Mark
[quote]By the way, can we change the time gap (1ms, for example) between the sampling input analogue signals?[/quote]Yes you can by changing the timer interval.
The lowest possible value is 2ms for the K8055N and 20ms for the K8055 due to USB communication limitations.
velleman.eu/products/view/?id=404880
“general conversion time: 2ms per command”
velleman.eu/products/view/?id=351346
“general conversion time: 20ms per command”
Okay. I will buy another board — K8055N. I use Visual Basic 2008 software to develop application program. If I get K8055N, is it easy to change sampling time as 2ms?
Thank you,
Mark
