K8055 bi directional motor control using PWM
I am looking to control the speed and direction of a 12v motor using a PWM (or DAC if easier) output of the K8055.
Is anybody aware of an external circuit that could either:-
a) use a single PWM output alone - eg 0 full reverse 128 stop 255 full forward.
b) use a single PWM and maybe one digital output as a directional control.
The external power source could supply both +12 and -12 volts if need be.
Thanks in advance,
Clive
i don’t have an answer but i would be interested if you find any results. thanks.
The post was answered here
viewtopic.php?f=15&t=3839
