I recently built a K8055 board and when i went to use it it appeared not to work at all. I played around with it and found it almost works with strange beheavour. If I plug the USB in I have to hold Input switch 3 in order for LD8 to blink. If I hold it I am able to connect with the demo software and control the outputs and see the inputs. I also tried removing IC2 and the board works/connects accept obviously the inputs dont work. Curiously when IC2 is removed inputs 1,2,4,5 report on and input 3 rports off. I have checked my component locations and joints several times I am certain there is more going on here. It seems very odd that it would behave mostly correct but different then intended. I am wondering if there is a problem with my PIC
Next test:
Remove IC2 and measure the voltage on pin 11 of IC3.
There should be +5V.
If not, then remove also IC3 and check the voltage on pin 11 again.
