hi, are the relays on the k8056 less than 100ma, i can’t find the coil switching rating. and if they are would the k8056 be a good choice to use with my k8055
cheers
cheers
K8056 features control transistors for the relays, so the current requirement meets K8055 specs.
thanks for a swift reply,
i’ll go buy 1 at the the weekend and try to make them work together
TO WHOM IT MAY CONCERN…
bought the k8056 board and when constructing it the voltage regulator named VR1
appears to be the wrong way around on the circuit diagram, i looked on the external packaging for the picture of the completed circuit and you can clearly see it is the other way round… i followed the picture from the box in the end and it works fine… is the circuit diagram wrong or was it me !!
