K8055 and digital sensor interfacing
I recently bought a flowmeter FS-4400H (digisavant.com/sensors-1-2.html) and want to connect it to a digital input of my K8055.
Sensor’s output is given as “open collector” from manufacturer.
Could someone help me : can I simply connect the sensor “as this” to the K8055 or do I need some electronics components to interface? I read somewhere something about a pull-down or pull-up resistor but have too few electronics knowledges to understand…
Thanks a lot for your help,
Marin
The open collector output of the sensor can be connected directly to the digital input of the K8055.
There is internal pull-up resistor on the K8055 board.
Thank you for answering.
Another question : could I power supply my sensor vith 12V or do I have to use 5V (same voltage as K8055)?
[quote=“mmmsmiley”]Thank you for answering.
Another question : could I power supply my sensor vith 12V or do I have to use 5V (same voltage as K8055)?[/quote]
You can use a 12V supply for the sensor power…
Thanks, I’m going to try!
