good morning
I would like my digital outputs operate with analog input A1.
BV.by 1 volt on the input A1,than are output 1 on
at 2 volt on the input A1,than are output 1,2 on
at 3 volt on the input A1,than are output 1,2,3 on
at 4 volt on the input A1,than are output 1,2,3,4 on
[quote=“ch@rles”]good morning
Sory for my bad englich
Thanks Charles[/quote]
hmm a K8055 voltmeter?
okay, if my understanding of the board is correct, A1 accepts 0-5v and gives values 0-255 so every 51 (255 divided by 5) is one volt
set the digital channel accordingly :-
(in this VB example I created a form and dropped a timer on it called Timer1, I also added a label called Label1 to display the volts on the form)
Public Class Form1
'You will be using these methods/functions so you need to have them declaired here
Public Declare Function ReadAnalogChannel Lib "k8055d.dll" (ByVal Channel As Integer) As Integer
Public Declare Sub SetDigitalChannel Lib "k8055d.dll" (ByVal Channel As Integer)
Public Declare Sub ClearAllDigital Lib "k8055d.dll" ()
Public Declare Function OpenDevice Lib "k8055d.dll" (ByVal CardAddress As Integer) As Integer
Public Declare Sub CloseDevice Lib "k8055d.dll" ()
Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
'timer setup
Timer1.Enabled = True 'Enable the timer
Timer1.Interval = 250 'Quarter of a second delay between readings
End Sub
Private Sub Timer1_Tick(sender As System.Object, e As System.EventArgs) Handles Timer1.Tick
OpenDevice(0)
Dim intVoltValue As Integer = ReadAnalogChannel(1) / 55 'This will be the reading from the analogue input converted to a Volt value
Me.Label1.Text = Str(intVoltValue) & " Volts" 'Displays the Volts on the form
ClearAllDigital()
For intOutChan = 1 To intVoltValue 'This will be the number of outputs that get set
SetDigitalChannel(intOutChan)
Next
CloseDevice()
End Sub
End Class
[quote=“chrisstubbs67”]
Public Class Form1
'timer setup
End Sub
OpenDevice(0)
ClearAllDigital()
Next
CloseDevice()
End Sub
End Class
C[/quote]
as a footnote if you change the timer tick event to :-
OpenDevice(0)
WriteAllDigital(ReadAnalogChannel(1))
CloseDevice()
End Sub
you have created a rather cool little 5v A/D convertor (okay deviating from the thread a little now)
An issue of which to be aware is that the ADCs on the K8055 use the USB’s 5V power supply as their reference voltage.
While the USB 5V supply on most computers is reasonably accurate (4.9 to 5.1V) the USB 2.0 specification allows 4.75 to 5.25 Volts. Some powered hubs using barely regulated “wall wart” power supplies are often higher than 5.25V with low loads, then drop off as multiple devices are connected.
Obviously this variance in the reference voltage of up to +/- 5% affects the accuracy of the 8055’s ADC inputs…
