Hi all, this is my first post and im just starting to learn pic programming.
I purchased the vm111 k8048 experimental board that came with a pic 16f627.
I managed to install everything correctly(i think).
I put the demo1(it came with the software as an example) onto the pic and when i turn the switch on the experimental board i see the leds light up(from LD1 to LD6) one at a time no problem there.
However when i take out the chip and try it on a prototype board no leds light up at all, i have tried to put only 1 led but still nothing. I connected 5v through pin 14 and a 3.3k resistor to pin 4 with the led connect from pin 6 to ground which is also connected to pin 5. I have been trying to fix it for ages please help is appreciated.
thanks
