The K8048 does work with a usb to serial adapter in Linux following the next link:
synapticloop.com/blog/2010/08/pr … -mac-os-x/
However this link is mac-related, the installation of gputils and dev.kewl.org/k8048/k8048.tar.gz makes it possible to program (at least an PIC16F628A) PIC’s
After installing gputils and the steps 1, 2 and 3 up to the “TexEdit”-piece, the compiled k8048 programs have to be installed as root: “make install”
The TextEdit piece didn’t work for me because there was no .bash_-profile file in my home-directory so I made one with vi:
vi .bash_profile
and put
export PATH=$PATH:~/bin/
in it.
Because my laptop doesn’t have a serial port, I deleted /dev/ttyS0 and softlinked my USB-port to the serial port (both as root):
rm /dev/ttyS0
ln -s /dev/ttyUSB0 /dev/ttyS0
This was to test wheather it was working.
Afterwards I copied the file ~/bin/k8048/Src/dotconf/K8048-ttyUSB0 to my home directory as .k8048
cp ~/bin/k8048/Src/dotconf/K8048-ttyUSB0 ~/.k8048
Now ttyUSB0 is always used by the program
Then I tried, from within the directory ~/.wine/drive_c/PicProg2009/Examples the commands:
k14 s PIC16F627 b
and
k14 s PIC16F627 b; gpasm -p p16f628A demo1.asm; k14 p demo1.hex
the first command worked, the second didn’t.
Then I compiled the demo1.asm with PicProg2009 (using wine) and found the demo1.hex file
again I tried, leaving out the compile stage:
k14 s PIC16F627 b; k14 p demo1.hex
and voila, it worked.
Note again: The HEX-file resides in ~/.wine/drive_c/PicProg2009/Examples/
To be sure I also tried the second demo which gave no problems as well.
In the meantime I tested the program on 16F627 and 16F628A and it works great
Hope this will help others a little bit to get the K8048 working with an USB-2-Serial-cable (which was a Prolilfic)
Berend van Assen
