You can download Picprog2009 from this link. http://www.vellemanusa.com/support/downloads/?code=K8048
Once you install it you will find the examples in c:\program files or Program files (X86) \Velleman\Picprog2009\Examples
I have not tried it with Windows 10 so I can not say.
Yes you will need to have a native serial port.
You will also need to power it with a non regulate 12 volt poser supply or a regulated 15 volt supply.
Nice. I am in your past shoes then. Congratulations!
Software downloaded nicely and I set the Hardware Configuration to K8048. The PicProg2009 connected smoothly and I have a green power LED. Switching to SW5 to “PROG” gives a blinking LED9.
I attempted to compile “BLINKLED.ASM” using MPASM v5.20 but received “Error in parameter” message followed by the filepath to “BLINKLED.ASM”.
My settings:
Radix: Hexadecimal.
Warning Level: All Messages.
Hex Output: INHX8M.
Generated Files: Error File and List File.
Case Sensitive: Checked.
Macro Expansion: Default.
Processor: 16F627.
Extended Mode: Unchecked.
Tab Size: 8.
Extra Options: blank.
I am reading through manual to see if I made a mistake. Any ideas? Thanks.
Additionally, can “DEMOF627.ASM” be downloaded from anywhere? Perhaps “BLINKLED.ASM” will not work with the PIC16F627.
You should try Demo1 or Demo2
These are written for the K8048 and the PIC16F627
I also use Notepad++ for viewing the files it keeps in in a very nice format
