Hello forum,
i just assembled a K8048 and everything looks fine. It’s just not working and LD8, the “read/write” LED is always on. The green power LED LD7 goes on and if i switch from Standby to Program or Run, LD9 starts flashing.
Unfortunately im not the best when it’s about electronics, so i could need some help finding the problem. What is the most probable problem? Is one of the transistors broken? I removed the Run/Standby/Program switch just to be sure, that there is nor problem with the switch, but that did not change anything.
Anybody who can make a good guess before i start to desolder everything?
Thanks,
Stefan
