If anyone can help with what I’m trying to do here that would be great. There is a Demo ASM file that comes with this kit that I’m looking to adjust. What I would like for it to do is instead of having each of the 4 tact switches doing 1 effect. I would like lets say for example Sw1 to cycle through multiple effects and then Sw2 to power on/off. The demo code that comes with it is below.
[code]
;* VELLEMAN High-Q KIT K8048/VM111 SAMPLE SOFTWARE *
;* Microchip PIC™ Programmer & experiment board *
;* DEMO2 program for testing K8048 with PIC16F627(A)! *
;* Generate 4 LED light effects, you can select these with SW1…4 *
;* © VELLEMAN Components,2003-2008 All rights reserved *
;* Hardw. Rev: P8048’1 Softw. Rev: 1.22 *
;* OSC…: XT 4MHz Max. POWER…: 12V DC *
W EQU H’0000’
F EQU H’0001’
;----- Register Files------------------------------------------------------
INDF EQU H’0000’
TMR0 EQU H’0001’
PCL EQU H’0002’
STATUS EQU H’0003’
FSR EQU H’0004’
PORTA EQU H’0005’
PORTB EQU H’0006’
INTCON EQU H’000B’
OPTION_REG EQU H’0081’
TRISA EQU H’0085’
TRISB EQU H’0086’
CMCON EQU H’001F’
;----- STATUS Bits --------------------------------------------------------
IRP EQU H’0007’
RP1 EQU H’0006’
RP0 EQU H’0005’
NOT_TO EQU H’0004’
NOT_PD EQU H’0003’
Z EQU H’0002’
DC EQU H’0001’
C EQU H’0000’
; RAM Definition
__MAXRAM H'01FF'
__BADRAM H'07'-H'09', H'0D', H'13'-H'14', H'1B'-H'1E'
__BADRAM H'87'-H'89', H'8D', H'8F'-H'91', H'93'-H'97', H'9E'
__BADRAM H'105', H'107'-H'109', H'10C'-H'11F', H'150'-H'16F'
__BADRAM H'185', H'187'-H'189', H'18C'-H'1EF'
; Configuration Bits
_BODEN_ON EQU H’3FFF’
_BODEN_OFF EQU H’3FBF’
_CP_ALL EQU H’03FF’
_CP_75 EQU H’17FF’
_CP_50 EQU H’2BFF’
_CP_OFF EQU H’3FFF’
_DATA_CP_ON EQU H’3EFF’
_DATA_CP_OFF EQU H’3FFF’
_PWRTE_OFF EQU H’3FFF’
_PWRTE_ON EQU H’3FF7’
_WDT_ON EQU H’3FFF’
_WDT_OFF EQU H’3FFB’
_LVP_ON EQU H’3FFF’
_LVP_OFF EQU H’3F7F’
_MCLRE_ON EQU H’3FFF’
_MCLRE_OFF EQU H’3FDF’
_ER_OSC_CLKOUT EQU H’3FFF’
_ER_OSC_NOCLKOUT EQU H’3FFE’
_INTRC_OSC_CLKOUT EQU H’3FFD’
_INTRC_OSC_NOCLKOUT EQU H’3FFC’
_EXTCLK_OSC EQU H’3FEF’
_LP_OSC EQU H’3FEC’
_XT_OSC EQU H’3FED’
_HS_OSC EQU H’3FEE’
__CONFIG _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
; Variable Definition
;INPUTS
SW1 EQU H’00’ ;SW1 is triggering RA0
SW2 EQU H’01’ ;SW2 is triggering RA1
SW3 EQU H’02’ ;SW3 is triggering RA2
SW4 EQU H’03’ ;SW4 is triggering RA3
TIMER1 EQU H’20’ ;Used in delay routine
TIMER2 EQU H’21’ ; " " "
PATERN EQU H’22’ ;Pattern data for effect’s
ORG 0 ;Reset vector address
GOTO RESET ;goto RESET routine when boot.
; * Example of a delay routine *
DELAY_ROUTINE MOVLW D’100’ ;54 Generate approx 10mS delay at 4Mhz CLK
MOVWF TIMER2
DEL_LOOP1 MOVLW D’100’ ;60
MOVWF TIMER1
DEL_LOOP2 BTFSC PORTA,SW1
GOTO MENU
BTFSC PORTA,SW2
GOTO MENU
BTFSC PORTA,SW3
GOTO MENU
BTFSC PORTA,SW4
GOTO MENU
DECFSZ TIMER1,F
GOTO DEL_LOOP2
DECFSZ TIMER2,F
GOTO DEL_LOOP1
RETLW 0
; ** RESET : main boot routine **
RESET MOVLW B’00000111’ ;Disable Comparator module’s
MOVWF CMCON
BSF STATUS,RP0 ;Switch to register bank 1
;Disable pull-ups
;INT on rising edge
;TMR0 to CLKOUT
;TMR0 Incr low2high trans.
;Prescaler assign to Timer0
;Prescaler rate is 1:256
MOVLW B’11010111’ ;Set PIC options (See datasheet).
MOVWF OPTION_REG ;Write the OPTION register.
CLRF INTCON ;Disable interrupts
MOVLW B’11000000’
MOVWF TRISB ;RB7 & RB6 are inputs.
;RB5…RB0 are outputs.
MOVLW B’11111111’ ;all RA ports are inputs
MOVWF TRISA
BCF STATUS,RP0 ;Switch Back to reg. Bank 0
CLRF PORTB
GOTO EFFECT_4
MENU CLRF PORTB
BTFSC PORTA,SW1
GOTO EFFECT_1
BTFSC PORTA,SW2
GOTO EFFECT_2
BTFSC PORTA,SW3
GOTO EFFECT_3
BTFSC PORTA,SW4
GOTO EFFECT_4
GOTO MENU
EFFECT_1 BTFSC PORTA,SW1
GOTO EFFECT_1
E1 MOVLW B’00100000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00110000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111100’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111110’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111111’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111110’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111100’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00111000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00110000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
GOTO E1
EFFECT_2 BTFSC PORTA,SW2
GOTO EFFECT_2
E2 MOVLW B’00000001’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00000010’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00000100’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00001000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00010000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00100000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00010000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00001000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00000100’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B’00000010’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
GOTO E2
EFFECT_3 BTFSC PORTA,SW3
GOTO EFFECT_3
E3 MOVLW B’00000111’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
CALL DELAY_ROUTINE
MOVLW B’00111000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
CALL DELAY_ROUTINE
GOTO E3
EFFECT_4 BTFSC PORTA,SW4
GOTO EFFECT_4
E4 MOVLW B’00001000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
CALL DELAY_ROUTINE
MOVLW B’00000000’ ;
MOVWF PORTB
CALL DELAY_ROUTINE
CALL DELAY_ROUTINE
GOTO E4
[/code]
Any help would be great as I’m totally new to this type of code. Thanks!
