is it possible to read the PIC18F852 over the ICSP Connector from K8048?
Martin
Martin
No all our PIC’s are read protected.
Sorry for my bad english.
I don´t won´t read the PIC from the K8048 board. I wan´t to know, if I connect an other board over the ICSP with the K8048. I can´t get the PIC18f852 out oft the other board. Can I read this PIC with the board?
Martin
I don’t find the PIC18F852.
Do you mean the PIC18F8520?
Yes, you are right.
Martin
Then it should be compatible, in fact you can check the Pickit 2 supported devices list.
Thank you for your help.
Martin
I may be wrong (it’s happened before) but I don’t see PIC18F8520 in the PicProg2009 list.
