i’ve to buy a k8047 kit for measuring 4 point electricity , in your software you have displayed only “DC Volt” but i need to change it in “AC VOLT” & " DC Ampere" although i put the correct tension (0-30 vdc ) in board input. It’s possible to change the graphic in the program?
Sorry but the K8047 is for DC measurement only. Due to the low sample rate it can’t measure AC volts. The graphic is also fixed.
You may use the DLL to make your own software for the K8047.
Download the k8047_pcs10_dll.zip
“K8047/PCS10 DLL and example to write your own software.”
