K8046
My hobby is tuning cars and thus this means that i always try to find something original or something very rare at the least. Now i saw someone who whas able to put the kit in his car so i am trying to do that also.
So i went to my local electronics guy and he set me up with the kit however i still have some questions.
1st - A cars battery is setup to suply 12V but this manages to change to 13V or 14V and also the same in the downwards direction. Can the kit handle this or should i put something (condensator???) between the Battery and the input. or perhaps an adapter and a (stopcontact?)
2nd - I managed to make the kit (eerste keer dat ik soldeer eigenlijk :D) but now i dont know what to get to actually use the switch. Is that the relay card K8056??
I dont need more switches for the moment and space is as limited as can be offcourse cause you never have enough free space inside a car :evil:
Anyways i hope someone can help me so i can keep on going,
Thanks in advance !
Have you visited the homepage for the K8046 (dutch)?
At the bottom you’ll find some pdf’s with schematics on how to connect each of them to the K8046.
Hope this helps
so the K8056 (got this out of the assembly manual) will do just fine.
Now how about the Volt? Voltage in a car can differ sometimes some cars deliver more then 12V and some cars deliver only 9V or so. Should i put something in between them?
15VDC will not be a problem. However, it is possible that with 9VDC, the relays will not energize. I doubt that this situation happens in a car with a healthy battery.
I want to buy this item but I don’t no it is want I need.
This touch panel it have the code function like k6400? I hope to answer me .Thank you
All I want to do is to open/close switch
This is not a codelock.
It provides toggle or pulse outputs.
But it is possible to use a keyboard shortcut to operate a relay?
Sorry, we do not understand your question, please elaborate.
