K8046-k6714
What is the maximum cable length to connect the K8046 with a K6714 relais card?
Richard
This has not been measured. It will also depend on environment, cable section etc… Determine by experimenting
Do you think about 5 meters is feasable??
Probably yes
However, you will need to try and experiment.
I have used 10 meters of alarm cable and it works perfect. 12 core type from Maplins.
