Is it possible to use the K8045 LCD Display kit as a thermometer readout?
I would like to be able to easily check on the temperature of my server cabinet.
K8045 is just a serial controlled readout.
You will need a temperature capturing device and some electronics that convert data from the sensor to a serial signal. You might want to look at dedicated solutions instead.
