K8044
K8044 Light effects generator
The Kit is not switching to any other lighting effect. After constructing the unit was powered up and all the lights flash on and off at the same time. The speed controller alters the flashing speed, but no other effects are accessible. Have you ever come across this problem? Or does this sound like a faulty PIC like some of the other faults reported on the forum?
Peter Rosoman
Peterrosoman,
On the channel selection jumpers you need to mount (1) jumper for the highest channel you will use.
If you are only going to use 5 channels mount (1) jumper in 5 CH.
If you are going to use 10 channels mount (1) jumper in 10 CH.
I hope this helps.
