Hello, I have an issue with the video cleaner module:
1.When power is switched ON :
Red led is continuously ON, Yellow led does 1 flash.
2.When there is no video signal on input :
Yellow led is OFF
When there is a standard video signal on input :
Yellow led is continuously ON
Video OUT signal is OK to TV
Video OUT signal is only black and white to VCR or PC video acquisition card (Haupauge). -
When there is a protected video signal on input :
So, there is no difference between standard and protected video signals.
The input signal is 1 V (peak to peak), the output signal is only 0.5 V.
There is no tuning component/device on PCB… Do you have any suggestion to correct the bug or what component to test/replace?
