I have just assembled and tested my K8035 kit and all works fine and does exactly what I needed, which is brilliant for a first attempt.
For my application what I would ideally like is to duplicate the displayed time so I see one side and that same time display is visible from the opposite side preferably with 2" LED’s.
Unless there is a simple way of doing it, one option would be to make another counter module and operate it from the same start switch.
Probably a naive question but, even if I could wire up bigger LED’s would I need to modify other components?
Thanks in advance
This would require quite large modifications, with which we unfortunately cannot assist.
The quickest and easiest solution would be adding a counter.
