I’m having a problem with K 8035 up/down counter. Device is giving me Error 5 and GOOD miscellaneously when turning the device on. If GOOD counter starts immediately to count up continuously. After resetting Error 5 the same thing. And if I thouch some metal for example resistor leg or some ground wire counter stops for a moment but starts to count up again. This is when 7, 8, 9 wires aren’t connected together.
If I connect 7, 8, 9 then device stays in zero but won’t let me count up when pushing up button. Only counting fast down when I keep on pushing down button. However when device is in SET mode counting up and down works well.
If you need to know something more just ask. There was a plenty of stuff to be explained.
Best regards Aki
