So On the assembly manual, I can switch the input between the born 8 and 9 on the connection… to send the impulsion on positive count/up or negative count/down.
But switching on the fly, Is there a risk to “reset” the memoy count?
I think no, as it is like pushing the down push button… but I ask before doing this.
So the Kit does the job, exterior impulse from a tripmaster, and changing count/decount “on the fly”…
and use the E.out, to sending the information to relay.
Unfortunately, Insering the kit in a box , I make a wrong thing, Since the auto control display “ERR 2” which means a keyboard error…
I think the PIC has a trouble…
For your information, the dipswitch in wrong position, make a “err3”.
Curiously in my system , I test the modulo 60 with inboard oscillator… is this as it was a chrono? because on my kit there is nothing on display (juste the “0000”) as I push a button.
If I need a new PIC to repare my kit, what is the procedure to keep it?
Check the keyboard lines. It displays an error when the buttons are pressed at power-up.
If the unit has been configured as ‘modulo-60’, the unit will count seconds and minutes or minutes and hours as long as the button is pushed.
