Hi everyone,
I’m using a 8035 kit and it works very well. I now would like to replace the standard 7 segment displays by bigger ones.
I have some common anode 2,3 inch (57mm) digit height (LTS-23805HRB) but of course it does not work that easily.
The first thing I tried is to lower R1 to R8 from 150 to 47 Ohm in order to increase the current in each segment. It barely reaches 4,4 mA… The highest current I can have is 24 mA by simply removing those resistors ! But it does not help lightening the segments.
My problem (or at least one of them !) is that the 7 segment displays are powered with 5V. It’s enough for the standard ones but each segment of a LTS-23805HRB contains 4 LEDs, wihch means that the threshold voltage is higher than the input voltage…
On top of that, there is a BC557 transistor in front of each 7 segment display (T1 to T4) and that greatly lowers the voltage arriving to each display. Before the transistor I measure indeed 5V but after the BC557 there is only 1,8V left to power each 7 segment display.
I have tried to change the resistors R9 to R12 from 10k to 2,2k but the voltage that arrives to the display only changes from 1,8V to 2,1V…
I have no idea on how to increase the voltage that powers the four 7 segment displays.
If anyone can help, I would be very grateful !
