K8035 as up&down counter only
Hi.
I want to use the counter to count on my coil winder.
I don’t want it to to continue counting when the winder stops on the position were the micro switch is.
If I can explain differently. If you press the up/down button for longer than 3 or 4 seconds the counter starts counting up or down on its own. I DON’T want that. Means it will not count the wingdings accurately.
I also do not need the timer H/M/S functions…
Is there a way I can eliminate the auto function mentioned in the 3rd line.
Regards Willie
