K8031 communication
I recently got my K8031 working but now im facing a new problem with my other computer. It works fine with the two laptops i have but i want to use it with my lab computer. When i plug in K8031 in the parallel port (in a real LPT port on the motherboard) and start PC lab it says that it cant make any connection with K8031. I have tested a several different modes in BIOS but none seems to work. I have a program that lets me view the LPT pins state. It says that Pin 14 is blinking when in run mode. Pin 2, 3 and 4 is always zero. If i manually activate 2 or 3 or 4 i recive input from K8031 and PC lab shows a signal but only one time. It seems to be either Windows or PC lab that is the problem.
I have now solved the problem. I dont know exacly why but on my computer the LPT pin 8 has be on all the time. It might have someting to do with the voltage output from the computer to K8031. To solve this problem i had to modify K8031.exe file in PClab2000SE. I recoded it so when pclab resets the output (387) to 0FFh it resets to 0BFh insted. Changing to to 0BFh insted of 0FFh will result 10111111 which means that bit 7 is not changed when the pc is sending data to K8031. If there are other with similar problem i can send you the modified K8031.exe.
It’s good to see you got your K8031 working.
This problem with the pin 8 of the LPT port seems strange.
Indeed, the main purpose of the pins 6, 7, 8 and 9 is to feed supply voltage to the optocouplers.
Also this pin 8 is feeding the pull-up resistor R41 for the optocoupler IC18.
Your solution seems to work but I don’t really understand it…
If you look this code snippet you’ll see that the pin 8 is set several times ON when the data is read from the K8031.
I thik you didn’t modify every instance…?
[code] asm
push ebx
push esi
push edi
    mov     edi,p2      {ds:BX = K   save address }
    mov     esi,p2
    add     esi,2*8192    {save address}
    mov     dx,pr_portti
    add     dx,2
    in      al,dx
    or      al,00000010b     {244 on}
    mov     ecx,5
@lo1:
    out     dx,al
    loop    @lo1
    mov     dx,pr_portti
    mov     ecx,cnt
@lo_16:
    mov	al,11111111b
out	dx,al
    out	dx,al
    mov	al,11111101b
out	dx,al
    out	dx,al
    loop    @lo_16
    mov	ecx,4096      {number of samples}
@looppi2:
    xor     bx,bx
     mov	al,11111101b
out	dx,al
    out	dx,al
inc	dx
in	al,dx
    in	al,dx           {b3, b7 now al bits b5 b6}
shl	al,2            {b3 --> b7, b7 --> cf}
    rcl     bl,8            {b7 --> bl b7}
    and     bl,10000000b
    or      bh,bl
    rol     al,4
    and     al,00001000b
    or      bh,al
dec	dx
    mov	al,11111100b
out	dx,al
    out	dx,al
inc	dx
in	al,dx
    in	al,dx           {b1, b5 now al bits b5 b6}
shl	al,2            {b1 --> b7, b5 --> cf}
    rcl     bl,6            {b5 --> bl b5}
    and     bl,00100000b
    or      bh,bl
    rol     al,2
    and     al,00000010b
    or      bh,al
    dec	dx
    mov	al,11111111b
out	dx,al
    out	dx,al
inc	dx
in	al,dx
    in	al,dx           {b2, b6 now al bits b5 b6}
shl	al,2            {b2 --> b7, b6 --> cf}
    rcl     bl,7            {b6 --> bl b6}
    and     bl,01000000b
    or      bh,bl
    rol     al,3
    and     al,00000100b
    or      bh,al
dec	dx
mov	al,11111110b
out	dx,al
    out	dx,al
inc	dx
in	al,dx
    in	al,dx           {b0, b4 now al bits b5 b6}
shl	al,2            {b0 --> b7, b4 --> cf}
    rcl     bl,5            {b4 --> bl b4}
    and     bl,00010000b
    or      bh,bl
    rol     al,1
    and     al,00000001b
    or      bh,al
dec	dx
    xor     ax,ax
    mov     al,bh
    mov     ds:[esi],ax
    add     summa,eax
    add     esi,4
loop	@looppi3
    jmp     @ready
@looppi3:
    jmp     @looppi2
    mov     eax,summa
@ready:
    mov     eax,summa
    shr     eax,12
    mov     ecx,16
@lop:
    mov     ds:[esi],ax
    add     esi,4
    loop    @lop
    mov	dx,pr_portti
    mov	al,0ffh
  	out	dx,al		{supply voltage to optocouplers}
    add     dx,2
    in      al,dx
    and     al,11111101b     {244 off}
    out     dx,al
    pop     edi
    pop     esi
    pop     ebx
 end;[/code]
