K8028
I build the K8028 Multifunctional Dimmer.
It is operating a LOAD of 10 50W/230V halogen-lights. I’m using function 9 (dim-on / dim-off) as operating-modus.
It is functioning allright except for one thing: at random times at random dim-levels the lights sometimes starts to flicker (sometimes slightly, sometimes heavy). When this happens and I put out the light (dim to zero) te light mostly flickers very heavy on the lowest dimlevel, just before actually going out.
Selftest does not adress any problems. Soldering-joints seem allright.
This is very anoying and I do not have a clue what the cause could be…
Do you have any idea?
Problem still not solved…does anyone please have an idea?
Meanwile I installed a Net-Filter (because it seems that the problem is coming from the powernet) but that does not make any difference…
Please, anyone??
Thnx!
[quote=“donQUIschot”]I build the K8028 Multifunctional Dimmer.
Do you have any idea?[/quote]
