I am using a K8028 Dimmer using function 5. I am using this PCB to control night lighting for a model railroad. I have a separate module for day light (yet to be installed)
I have the Delay1 & Delay2 timers programmed at 7 minutes.
The Dimmer is attached to 3 85 Watt blue incandescent flood bulbs installed on track lighting. totaling 255 Watts.
Everything functions great until just before the lights go out on the slow off. At this point the lights begin to flicker aggressively. The problem only ceases if I remove one of the three lights.
If I am correct this PCB is designed to handle 300 Watt?
I have traced all my wiring, double and triple checked my earth ground, I’m puzzled as to what the problem may be other than too much load on the board.
I welcome and help offered… Thanks
Steve Hofmeister
