K8026 - range?
I have just tested my sons K8026 with a 40W light bulb. The dimming range seems very small. The light bulb is already bright when switched on, and only gets fractionally brighter.
Is this correct?
If on 230 Volts: hope you did not mount R2? On 230 Volts minimal lamp/load is 60 Watts.
I’m using 230V and yes - I mounted everything - including R2.
Ah yes - missed that part in the manual! R2 removed, and all is well!
Ok, solved quickly :stuck_out_tongue:
EXCEPT that on the 3rd attempt to use it, something has blown :frowning:
Not very good news… your lamp got broke and meanwhile made a short circuit? Check fuse and triac in that case.
