K8023
is it possible to run two K8023 over 3-wire(1 GND; 2 +) bidirectional?
Thank you very much for answer.
This could work if you use the ‘+’ as a common, not the ‘-’, since the ‘-’ is not at ground level.
Thank you for your answer,
but I need to know if it works, before I buy two K8023.
We see no obvious reason why it would not work.
Sorry, we do not have the means to provide ‘testing on demand’, this would be too timeconsuming.
Thanks for your understanding.
Thank you. I hoped somebody had tried it already. November I have bought two kits…
