So, I am wondering what the behavior of the K8023 is when it loses its serial I/O stream.
1)Do all of the outputs retain there current states on loss of data?
2)If they do, is the system stable when serial comm resumes, or does it “reset” before processing the resumed serial stream?
3)Do they revert do a default state (and what stats is that?)
4)Does anyone have any input on how stable and reliable the K8023 is with regard to data?
5)If I were to use the K8023 to power my own relays, what is the maximum current draw a) per channel and b)for all outputs simultaneously?
And as for the K6714…
- I am unclear as to what the resistive coil load/ current draw is for each relay. Can all 8 (or 16) relays be on at once for an extended period of time with regard to power supply size?
Thanks!
Bill
