The kit was purchased on 16thApril 2009 and great care was taken in soldering the components.
Replacement of one of the Voltage regulator was made during the construction due to poor soldering.
On testing the unit was switched on without the IC’s included. The power LED lit so all was assumed well.
I proceeded with adding the IC’s ;’ switched the unit on and the control leds functioned correctly for each input.
However when I measured the voltage at J8 and J9 against ground there was no voltage.
I added the lid and tested the unit with a CD input and line output. There was only one channel working at low volume and highly distorted.
The IC2 OP amp was also running hot.
I have checked all the soldering and can’t find any problems. The GND is sepated via R52 470 ohm resistor . Is this correct:
Proably, the output of the IC is shorted or loaded with a very low impedance.
Remove power and remove IC. Check with multimeter.
If there are no obvious assembly problems, examine PCB tracks for possible etching errors.
Follow complete path of tracks and components connected to pin 6.
If necessary, remove components.
Check for etching error between track and GND plane.
For IC2 pin 6 shorting to GND I found a tracking error close to R31.
Also for IC3 pin 3 was shorted to GND. I eventually foound where the track error was for this, but had to take of the ALPS. Taking off compontets doesn’t do the PC track any good so I had to bridge some of the PC tracks with wire.
However now the unit works very sweetly for the PU and CD inputs.(Haven;t used the others)
I also I am driving the power amp for A 28 year old NAD 3020 which works fine. As the preamp for this fried along time ago.
Thanks for your help on this.
Now I have got the kit bug I may purchase the MOSFET amps in the long term, but only when you have widened the gap of the PCB tracks.
