Dear support people of Velleman
I refer to my questionof a week ago, on which I did not receive an answer. For a client seeking advice on actually buying two new products, I suppose you overlooked my question. I post it here again.
quote
I have today a K8020 valve preamp and a K4040 valve power amp. As valve power amps tend to be weak in the bass region, I would consider to use the 4040 on the high/mid of my biamp speakers (tanoy 613i sixes) and acquiring a K8040 set of two for the bass, using the bypass function of the 8040.
- Has anyone had any experience in doing so?
- As the input impedance and sensitivity of the 8040 and 4040 seem different, would this cause a problem (ex different volume levels on my bass and high/mid)
- If so, is there any workaround?
unquote
thanks for your reply
