I have recently completed my K8020. When I wanted to fire it up for the first time, LED08 (The high voltage indication LED) does not light up. The power indication and input sellection LED’s function as they should.
I am from Holland and our net voltage is 230VAC. I have connected B&C to achieve the correct voltage but I measure 115VAC between the bridge and the neutral wire from the power input.
Also I measure 3VDC at the input LED’s instead of 5VDC which is indacted on the PCB.
I suspect relais RY9 either not functioning or not getting the correct voltage.
Note: Relais mounted is type VR5V122C where as mounting instructions indicate type VR5C122C.
The relais is not switching and solid black instead of transperant.
If anyone has a solution for this problem I would be very glad.
Hello! Léo does not answer and i stay alone with m’y kit out of use .Léo ne répond pas et je reste seul avec mon kit qui ne fonctionne pas . CAN you help me now ? Pouvez vous m’aider maintenant ? Tank you . Merci .
