I have had a k8020 preamplifier for some time. It has been working without problems so far but now it has developed a fault. At power-on the buttons may work for some minutes but fail to respond properly after a while. Most often the buttons do not respond properly even after power-on.
I have checked that all voltages are correct. The PIC gets 5V and the RC oscillator is working. So I assume the PIC is faulty.
[quote=“VEL417”]Please return PIC for inspection/exchange to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium[/quote]
I sent my PIC to the above address over a month ago. I haven’t received any replacement nor have anyone contacted me (I included my email-address). Is there an email address for Velleman Tech. Department or some other means to contact them?
[quote=“VEL417”]Sorry, but we did not receive your PIC.
Most likely, it got lost in the mail.
As a one-time courtesy we can send a new PIC, if you provide an address.[/quote]
Is there a way to send my address without using this public forum (e.g. by email)? My email address can be found from my profile.
regards
Martti
I received the new PIC last week. At first it had the same symptoms as the original PIC. However after disassembling the main PCB from the chassis I noticed some grounding issues (loose nuts). Fixing those also solved the problem with the PIC.
