I have the following question regarding the K8020 capacitors that are listed in the user manual on page 7. There are a total of 13 capacitors numbered from C1:220p throughout C7:220p
(see user manual pictures: 3.Capacitors http://i46.tinypic.com/6en5e1.jpg
Sorry, you have us confused here.
Could you supply pictures of the caps?
Please look at the other side of the cap, it indicates the value.
If not, then for some reason the printing is missing.
In that case, please let us know which caps you are missing so that we can mail them.
First off, excuse me for the late reply but I couldn’t find any time to look into the issue again earlier.
As you have said, the backside of the cap indicates the value, all of them are imprinted with a 220p. Only the front sides have different numbers (different values? ) on them. Do those in front simply have no meaning at all or is there a specific order or purpose for them?
So, they are 220p capacitors.
The numbers at the back are for production only, don’t worry about them.
Is your problem solved now or do you have any other issues?
Okay, thank you very much for this information. I did not know those were simply manufacturing numbers. Learnt something new. Thanks for your help again!
