hello,
i’m trying to get life to this generator. It was built by my friend but never working.
here’s what I’ve checked:
all components are on the right places
voltages on regulators are OK (+5V,-5V,+12V,-12V)
communication with PC works fine,LD2 lights when I click waveform button
power consumption is about 0.6A
If you have an oscilloscope you can check the signal path.
First check the signal on pin 6 of IC33.
If no signal then check the digital-to-analog converter IC6 outputs.
If still no signal then check the IC6 data and clock inputs.
If there is waveform found on pin 6 of IC33 then follow the signal path to the output via IC14, R50, IC13, RY1 to try to find the problem.
Do you see any data on the address pins A0…A14 of IC10 when the generator is set to output some signal?
Also check if there is any data on these pins when you change the signal frequency or the amplitude setting and the waveform button is pressed “down”.
This should load new data to the RAM and the address inputs should change states.
Also on the data pins D0…D7 there should be some pulses seen.
Please check that there is 320Hz frequency clock pulses on pin 9 of IC22.
This indicates that the oscillator X1 and the counter chain IC8, IC4, IC11 is working correctly.
It seems that either DATA, CLK1 or RCK1 to IC2 is missing.
You should see about 1 second burst of fast pulses to CLK1 and to DATA inputs when the frequency slider is changed and the sine button is kept pressed down.
To the RCK1 input there are sent two pulses from IC22. Pulse length about 10us.
I am getting those fast pulses now to pin 14 of IC2 when I’m pressing sine button or hz button. But no pulses pin 11 of IC2. Also no state change on D0-D7 on IC2.
Do you see any pulses on pin 1 of IC22 when you click the sine button down?
Please see this thread: viewtopic.php?f=11&t=4277
There are screenshots of the waveforms measured on pin 1, 2 and 3 of IC22.
The single shot mode is used in the oscilloscope.
[quote]i’ve edited my previous post with additional info about IC19 and IC21 states.[/quote]Yes, I see.
For some reason IC21 data seems to be OK.
The main problem is that the IC22 is not getting the pulses to pins 2 and 3.
The problem is somewhere around IC35 and IC36.
Please check the resistors R74 and R75 are 100 ohm.
Now you have to check the input side of the optocouplers IC35 and IC36.
Connect the oscilloscope ground to the mounting bracket of the 25 pin cable connector.
Check the pulses on pin 3 of IC35 and IC36.
The pulse amplitude should be about 3V.
Also check the voltage over C11. Should be about 3V or more.
