Hello there.
Is there any way i can trigger my K8015 with a BJT BC547 transistor?
I have a 1.8v with a 1k resistor to the base. I’m feeding 12v to the k8015 board, and i was wondering if there is anyway i could make it work to trigger it.
I just can’t change base voltage.
Also tried to permanently close the trigger circuit and use the bc547 to feed power to the board (i was giving 12v to the board, outputting the “negative” to the collector and putting the emitter to ground) but i had no success (i think it was because the k8015 has a diode bridge).
Do you have any ideas i could use?
Thank you.
