Hi from Marco.
I am trying to use 5 k8015 as activators for a self made anti burglar alarm in my firm.
When the alarm is activated (it works via a pc and 7 K8000 cards as input and output controllers) the output commands 2 K2633 cards.
One of these output is meant to close the contacts of these 5 k8015 used as short interval timers that command the internal lights of the firm, creating a “quasi strobo” effects of the whole firms lights as a further deterrent, as they are set with different and very short delay 1 and 2 (10/2 seconds, 15/3 seconds and 20/4 seconds).
Any card is meant to command the contact of one Osram controller (as the light are batteries of fluorescent auto dimmerable lights), simulating the on/off normal switch as it is put in parallel with it.
My problem is this:
As soon as I give main to the k8015, there is present a contact between Common and Normally Open (i mean Open!) contacts in the relay, so the lights go on even if there is no such command from the alarm via K8000 and K2633.
More, I cannot put the transient suppressor jumper as it immediately closes the circuit.
Maybe it is any problem related to the osram controller? are they too much sensitive? or maybe some unwanted loop can close the circuit?
Can You help me?
Maybe using a diode in the relay command could help?
Thanks,
Marco
