i’ve bought the K8015 kit for experimental use. If by error i damage the PIC, can i order a new one ? if so, where ?
Thx.
Your Velleman distributor (i.e. the place where you have bought your kit) would be the best place to look for spare parts.
[quote=“Backbird”]i’ve bought the K8015 kit for experimental use. If by error i damage the PIC, can i order a new one ? if so, where ?
Thx.[/quote]
Hi Support team> Have purchase the same kit K8015 (Multifunction Relay Switch) way back 5 years ago and just to inquire if i can possibly order for a replacement IC<> PIC12 CE518? I tried to order the item thru RS Electronics/Singapore however, the IC didn’t work as i was advice this IC is a programmed IC controller. Please advice on how to order the mention IC name. I purchased this Kit 8015 in Dubai. Many thanks for your time
PS> Please advice of any sales reps/distributor located in Singapore or around Asia Pacific where i can order. Thanks
Sorry, no direct sales.
You will have to turn to a distributor. Order code: VK8015
Distributors do not stock spare processors, they will have to order it for you.
Most likely, the quickest and cheapest solution is to buy a second kit.
