I broke the switch of my K8011 amplifier.
In order to replace it, I’d need to know what are the pins connections in each position.(off, stand by an on)
Thanx
Thanx
You can order this spare part at your local dealer, our ref: 812.
I’ve just contacted my local dealer that answered this switch is not avalaible until May…
I am using this amplifier as guitar power amplifier, and I need it every week.
I would be grateful if you could give me the connection table between the 6 pins of the switch (corresponding to the numbers written on the PCB).
Thanx
Thank you, I am going to deal with it.
Sorry, but just one more question.
If the central position of the switch stands for the amplifier stand-by, which position is for the off or the on : out on pin 6 or out on pin 1?
Thanx
Please check p20 of the assembly manual.
I’ve read p20, I doesn’t indicate what I search for.
I cannot replace the switch because it’s not available, it’s a specific product and I have to find a solution before tomorow evening, so I will create a system of my own respecting the original contacts configuration.
But I have to know whitch position stands for the OFF and the ON, I don’t want to damage my amplifier.
