How can I use my K8006 to dim LED lamps
I think the K8037 is a leading edge dimmer and I understand LED lamps require a trailing edge dimmer?
Sorry, you cannot use it to dim led lamps, unless the lamps have been designed to be used with a leading edge dimmer and even then, only testing will reveal if it will work correctly with that particular type of led lamp.
