K8005 stepper motor card
hi,
i recently buy assembly kit k8005, now i try to soldering it. My problem is, when i solder PCB i didnt paying attention, so i dont know if i do it right or not :frowning: , can someone be so kindly and look on to PCB board and verify me if contact of J7 and R10 are really connected, i will appriciate that.
thx in advance
regards
hi,
when i was puting together my 4-th k8005 card i test it, and doesent work, in quick checkup i noticed that i made a mistake with transistors, T11 and T12 was switched, i switch it on the right positione and test it again and still doesent work, how big damage i did with switching that two transistors?, can that damage be repaired.
Thanks for answers
regards
any hint please
regards
Most likely, transistors are defective, better to replace them.
There can be more than one problem, most likely assembly or solder problem.
thanks for reply.
i leave an open option for bad assemblyor soldering, but ill first replace transistors an post it here if it works or not
regards
i replace transistors and k8005 still doesent work, it seems something else is damaged also, i checked all diodes and work fine, im afraid that IC-s are damaged, any idea what else i can do?
regards
Can you link to HI-RES and SHARP pics of both component and solderside, so that we can take a look at your assembly.
pic are made with n95 5M pixels
shrani.si/f/2z/8H/1PQrBaXY/04042011106.jpg
shrani.si/f/1t/J0/1PJGvsRq/04042011107.jpg
shrani.si/f/I/jx/1XDrtzxK/04042011108.jpg
shrani.si/f/1y/gr/OgTWEnG/04042011109.jpg
shrani.si/f/2H/ho/xEhO4e1/04042011111.jpg
regards
i test both of transistors that was switchet (stickycarpet.com/pinx/test.html), it seems to transistors are OK, i allerady see that will be very dificult to find a error on pcb.
i today assembled another K8005 card, it works fine, si i put all IC-s on working card, card work fine, so IC-s arent damaged, im running out of ideas, i also replacet 7805 with new one (excatly same)?!
regards
p.s: when i press STEP button motor start to make a little noise, it doesent turn but if u hold it in hand u can fell that he want to turn but he dont
i replaced all 12 transistors, card still dont work?
regards
