K8005 addressing problem
I am now able to drive one stepper motor; however, when I hook up another motor card I can’t address them seperately.
The switches on one card are set to “0000” and on the other card “1000”.
I took a step back and tried debugging using TEST K8005. Both of the motors turn together, but only one motor (address “0000”) is OK. Why doesn’t it say address “1000” is OK or address “1000” KO? Why can’t they be controlled seperately?
The way I’ve connected the controllers is as follows:
Used one 3 ribbon cable to connect GND, SDA, SCL between K8000 and first K8005, then another 3 ribbon cable to connect GND, SDA, SCL of first K8005 to second K8005.
I’ll eventually need to drive four stepper motors in total.
Regards,
Kris.
is happening.
Of the 3 possible motor controls in TEST K8005, only the first one is OK (drives both motors with different addresses set on the hardware), the other two are KO. The wierd thing is that I can control the speed of the two motors by turning the dial on either of the two controls below, even thought they say the motor is KO. I can’t change the direction with the bottom two controls though.
I tried debugging using the ReadMotor procedure.
(1) ReadMotor 0 returns 1 when switches on stepper motor card set to “0000”
(2) ReadMotor 15 returns 255 when switches on stepper motor card set to “1111”
(3) Strangely, when two motor cards connected and set to any address other than “0000”, when I repeat ReadMotor 0, it still returns 1.
What’s going on?
Kris.
bump
Do you have any source code you can post?
Admin note: Please don’t create meaningless topics if your problem doesn’t get solved right away, be patient and someone should answer. All duplicate posts have been deleted.
Here is the code that I’m using. I’m also running it on an old machine (Windows 98 2nd edn) as it doesn’t work on the brand new Dell (XP) that we bought for it.
Regards,
Kris.
'This unit contains procedures and functions for use with the 'VELLEMAN Stepping Motor Card K8005'
'I2C BUS CONDITIONS
DECLARE SUB SelectI2cPrinterPort (PrinterNo)
DECLARE SUB I2CBusNotBusy ()
DECLARE FUNCTION BINNOT (Dec)
DECLARE SUB I2CInit ()
DECLARE SUB I2Cmasterclockpulse ()
DECLARE FUNCTION I2Cinput ()
DECLARE SUB I2Cstart ()
DECLARE SUB I2Coutput (SerData)
DECLARE SUB I2Cclockpulse ()
DECLARE SUB I2Cstop ()
DECLARE FUNCTION SHL (Dec, Positions)
DECLARE SUB SpeedTestText ()
DECLARE SUB SpeedTestNText ()
'RADIX CONVERSION
DECLARE FUNCTION BinToDec (BinNumber$)
DECLARE FUNCTION DecToBin$ (DecNumber)
'OUTPUT SUBROUTINES FOR ONE CARD
DECLARE SUB SendMotor (MotorNo, Commando, time, steps)
'STEPPING SUBROUTINES FOR ONE CARD
DECLARE SUB SendStepCCWFull (MotorNo, time, steps)
DECLARE SUB SendStepCCWHalf (MotorNo, time, steps)
DECLARE SUB SendStepCWFull (MotorNo, time, steps)
DECLARE SUB SendStepCWHalf (MotorNo, time, steps)
DECLARE SUB SendstepCW (MotorNo, time, steps)
DECLARE SUB SendstepCCW (MotorNo, time, steps)
DECLARE SUB SendStepHalf (MotorNo, time, steps)
DECLARE SUB SendStepFull (MotorNo, time, steps)
DECLARE SUB SendstepPING (MotorNo, time, steps)
' SETTING SUBROUTINES FOR ONE CARD
DECLARE SUB SendSetFree (MotorNo)
DECLARE SUB SendSetTake (MotorNo)
DECLARE SUB Sendstop (MotorNo)
DECLARE SUB SendSetCW (MotorNo)
DECLARE SUB SendSetCCW (MotorNo)
DECLARE SUB SendSetHalf (MotorNo)
DECLARE SUB SendSetFull (MotorNo)
DECLARE SUB SendSetCWFull (MotorNo)
DECLARE SUB SendSetCWHalf (MotorNo)
DECLARE SUB SendSetCCWFull (MotorNo)
DECLARE SUB SendSetCCWHalf (MotorNo)
' OUTPUT SUBROUTINES FOR ALL CARDS
DECLARE SUB SendAllMotors (Commando, time, steps)
' STEPPING SUBROUTINES FOR ALL CARDS
DECLARE SUB SendAllStepCCWFull (time, steps)
DECLARE SUB SendAllStepCCWHalf (time, steps)
DECLARE SUB SendAllStepCWFull (time, steps)
DECLARE SUB SendAllStepCWHalf (time, steps)
DECLARE SUB SendAllstepCW (time, steps)
DECLARE SUB SendAllstepCCW (time, steps)
DECLARE SUB SendAllStepHalf (time, steps)
DECLARE SUB SendAllStepFull (time, steps)
DECLARE SUB SendaLLstepPING (time, steps)
' SETTING SUBROUTINES FOR ALL CARDS
DECLARE SUB SendAllSetFree ()
DECLARE SUB SendAllSetTake ()
DECLARE SUB SendAllStop ()
DECLARE SUB SendAllSetCW ()
DECLARE SUB SendAllSetCCW ()
DECLARE SUB SendAllSetHalf ()
DECLARE SUB SendAllSetFull ()
DECLARE SUB SendAllSetCWFull ()
DECLARE SUB SendAllSetCWHalf ()
DECLARE SUB SendAllSetCCWFull ()
DECLARE SUB SendAllSetCCWHalf ()
'INPUT SUBROUTINES
DECLARE SUB Readmotor (MotorNo)
DECLARE SUB ReadAllMotors ()
'COMMON USED CONSTANTS AND VARIABLES
CONST MaxMotorCards = 15
COMMON SHARED Statusport, ControlPort, I2cBusDelay, Overwrite, WaitTime
DIM SHARED motorcardcode(0 TO MaxMotorCards)
	FOR CardNo = 0 TO MaxMotorCards
		motorcardcode(CardNo) = 192 + (2 * CardNo)
	NEXT
DIM SHARED MotorCardData(0 TO MaxMotorCards)
I2CInit
'Example 6
SpeedTestText
	'#################### DEBUG ##################################
	PRINT ""; CardNo
	Readmotor 0
	IF MotorCardData(0) = 1 THEN PRINT "MotorCard 0 is ready to receive data"
	IF MotorCardData(0) = 127 THEN PRINT "The memory of the stepper motor card 0 is full"
	IF MotorCardData(0) = 255 THEN PRINT "The motor card 0 is not connected or powered on"
	Readmotor 15
	IF MotorCardData(15) = 1 THEN PRINT "MotorCard 15 is ready to receive data"
	IF MotorCardData(15) = 127 THEN PRINT "The memory of the stepper motor card 15 is full"
	IF MotorCardData(15) = 255 THEN PRINT "The motor card 15 is not connected or powered on"
	PRINT "Press enter to continue"
	INPUT a$
	time = 10
	steps = 1000
	motor = 0
	SendStepCWFull motor, time, steps
END
	Temp$ = DecToBin(Dec)
	Complement$ = ""
	FOR i = 1 TO LEN(Temp$)
		IF MID$(Temp$, i, 1) = "1" THEN
			Complement$ = Complement$ + "0"
		ELSE
			Complement$ = Complement$ + "1"
		END IF
	NEXT
	BINNOT = BinToDec(Complement$)
END FUNCTION
	Weight = 1
	Dec = 0                        'Reset decimal number
	IF BinNumber$ <> "00000000" THEN
		FOR i = LEN(BinNumber$) TO 1 STEP -1
			IF MID$(BinNumber$, i, 1) = "1" THEN
				Dec = Dec + Weight     'If bit=1 then add weigth factor
			END IF
			Weight = Weight * 2    'Multiply weight factor by 2
		NEXT
		BinToDec = Dec          'Store result
	ELSE
		BinToDec = 0
	END IF
END FUNCTION
'RADIX CONVERSION
	'Conversion of decimal number (0...255) to 8 bit binary string.
	Bin$ = ""
	faktor = 128
	IF DecNumber <> 0 THEN
		FOR i = 1 TO 8
			IF faktor > DecNumber THEN
				Bin$ = Bin$ + "0"
			ELSE
				Bin$ = Bin$ + "1"
				DecNumber = DecNumber - faktor
			END IF
			faktor = faktor \ 2
		NEXT
		DecToBin$ = Bin$
	ELSE
		DecToBin$ = "00000000"
	END IF
END FUNCTION
SUB I2CBusNotBusy
	OUT ControlPort, 4
END SUB
SUB I2Cclockpulse
	OUT ControlPort, 12
	FOR i = 0 TO I2cBusDelay
	NEXT
	OUT ControlPort, 4
	NEXT
	OUT ControlPort, 12
	NEXT
END SUB
SUB I2CInit
	SelectI2cPrinterPort 1
	I2cBusDelay = 20
	I2CBusNotBusy
	Overwrite = 0
	WaitTime = 300
	ReadAllMotors
END SUB
FUNCTION I2Cinput
	SerData = 0
	FOR j = 1 TO 8
		SerData = SHL(SerData, 1)
		OUT ControlPort, 4
		NEXT
		Inputdata = INP(Statusport) AND 16
		IF Inputdata <> 0 THEN
			SerData = SerData OR 1
		END IF
		OUT ControlPort, 12
		NEXT
	NEXT
	I2Cinput = SerData
END FUNCTION
	OUT ControlPort, 14
	NEXT
	OUT ControlPort, 6
	NEXT
	OUT ControlPort, 14
	NEXT
	OUT ControlPort, 12
	NEXT
END SUB
	Temp = SerData
	Serdat$ = DecToBin(Temp)
	FOR j = 1 TO 8
		IF MID$(Serdat$, j, 1) = "1" THEN
			DataOut = 12
		 ELSE
			DataOut = 14
		END IF
		OUT ControlPort, DataOut
		NEXT
		DataOut = INP(ControlPort) AND 7
		NEXT
		DataOut = INP(ControlPort) OR 8
		NEXT
	NEXT
END SUB
SUB I2Cstart
	NEXT
       OUT ControlPort, 6
	NEXT
	OUT ControlPort, 14
	NEXT
END SUB
SUB I2Cstop
REM     OUT ControlPort, 14
	NEXT
REM     OUT ControlPort, 6
	NEXT
	OUT ControlPort, 4
	NEXT
END SUB
SUB ReadAllMotors
	FOR counter = 0 TO MaxMotorCards
		Readmotor counter
	NEXT
END SUB
' INPUT SUBROUTINES
SUB Readmotor (CardNo)
	FOR time = 1 TO I2CWaitTime: NEXT time
	I2Cstart
	DataVar = motorcardcode(CardNo) OR 1
	I2Coutput DataVar
	I2Cclockpulse
	MotorCardData(CardNo) = I2Cinput
	I2Cclockpulse
	I2Cstop
END SUB
' I2C COMMUNICATION SUBROUTINES
	SELECT CASE PrinterNo
		CASE 0
			Statusport = 957
			ControlPort = 958
		CASE 1
			Statusport = 889
			ControlPort = 890
		CASE 2
			StatusPost = 633
			ControlPort = 634
	END SELECT
END SUB
'OUTPUT SUBROUTINES FOR ALL CARDS
Temp1 = Commando
Temp2 = time
Temp3 = steps
	SendMotor counter, Temp1, Temp2, Temp3
NEXT
END SUB
SUB SendAllSetCCW
	SendSetCCW counter
NEXT
END SUB
	SendSetCCWFull counter
NEXT
END SUB
	SendSetCCWHalf counter
NEXT
END SUB
SUB SendAllSetCW
	SendSetCW counter
NEXT
END SUB
	SendSetCWFull counter
NEXT
END SUB
	SendSetCWHalf counter
NEXT
END SUB
'SETTING SUBROUTINES FOR ALL CARDS
SUB SendAllSetFree
	SendSetFree counter
NEXT
END SUB
SUB SendAllSetFull
	SendSetFull counter
NEXT
END SUB
SUB SendAllSetHalf
	SendSetHalf counter
NEXT
END SUB
SUB SendAllSetTake
	SendSetTake counter
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendstepCCW counter, Temp1, Temp2
NEXT
END SUB
'STEPPING SUBROUTINES FOR ALL CARDS
Temp1 = time
Temp2 = steps
	SendStepCCWFull counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendStepCCWHalf counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendstepCW counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendStepCWFull counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendStepCWHalf counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendStepFull counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendStepHalf counter, Temp1, Temp2
NEXT
END SUB
Temp1 = time
Temp2 = steps
	SendstepPING counter, Temp1, Temp2
NEXT
END SUB
SUB SendAllStop
	Sendstop counter
NEXT
END SUB
' OUTPUT SUBROUTINES FOR ONE CARD
	IF Overwrite = 0 THEN
		MotorCardData(MotorNo) = 55
		WHILE (MotorCardData(MotorNo) <> 1) AND (MotorCardData(MotorNo) <> 255)
		Readmotor (MotorNo)
		WEND
	END IF
	FOR T = 1 TO I2CWaitTime: NEXT T
	I2Cstart
	Temp = motorcardcode(MotorNo)
	I2Coutput Temp
	I2Cclockpulse
	Temp = Commando
	I2Coutput Temp
	I2Cclockpulse
	Temp = time
	I2Coutput Temp
	I2Cclockpulse
	Temp = (steps - (steps MOD 255)) / 255
	I2Coutput Temp
	I2Cclockpulse
	Temp = steps MOD 255
	I2Coutput Temp
	I2Cclockpulse
	I2Cstop
END SUB
Temp = MotorNo
SendMotor Temp, 96, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 112, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 120, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 64, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 80, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 88, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 4, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 16, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 24, 0, 0
END SUB
Temp = MotorNo
SendMotor Temp, 6, 0, 0
END SUB
' STEPPING PROCEDURES ONE CARD
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 231, Temp1, Temp2 ELSE SendMotor Temp, 230, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 247, Temp1, Temp2 ELSE SendMotor Temp, 246, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 255, Temp1, Temp2 ELSE SendMotor Temp, 254, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 199, Temp1, Temp2 ELSE SendMotor Temp, 198, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 215, Temp1, Temp2 ELSE SendMotor Temp, 214, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 223, Temp1, Temp2 ELSE SendMotor Temp, 222, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 151, Temp1, Temp2 ELSE SendMotor Temp, 150, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 159, Temp1, Temp2 ELSE SendMotor Temp, 158, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = time
Temp2 = steps
IF steps = 0 THEN SendMotor Temp, 135, Temp1, Temp2 ELSE SendMotor Temp, 134, Temp1, Temp2
END SUB
Temp = MotorNo
Temp1 = Overwrite
Overwrite = 1
SendMotor Temp, 0, 0, 0
Overwrite = Temp1
END SUB
	Temp$ = RIGHT$(DecToBin(Dec) + STRING$(Positions, "0"), 8)
	SHL = BinToDec(Temp$)
END FUNCTION
SUB SpeedTestNText
CLS
I2CWaitTime = 2000
I2cBusDelay = 0
counter = 0
DO
      counter = counter + 1
      I2cBusDelay = counter
      Readmotor (0)
LOOP UNTIL ((MotorCardData(0) = 1) OR (counter = 32000))
DO
	reliable = 1
	FOR counter2 = 1 TO 30
		   Readmotor (0)
		   IF MotorCardData(0) <> 1 THEN reliable = 0
		NEXT counter2
	IF reliable <> 1 THEN counter = counter + 1
LOOP UNTIL reliable = 1
END SUB
SUB SpeedTestText
CLS
I2CWaitTime = 2000
PRINT "TEST PROGRAM K8005 FOR QuickBasic"
PRINT "***********************************"
PRINT "I2C bus is free, set the K8005 to work as steppermotorcard zero and switch the unit on"
PRINT "Press enter when ready"
INPUT a$
PRINT "Speed testing"
I2cBusDelay = 0
counter = 0
DO
      Readmotor (0)
PRINT "Value found for the I2CBusDelay", counter
DO
	reliable = 1
	PRINT "Testing reliability of value", counter
		   Readmotor (0)
		NEXT counter2
	IF reliable = 1 THEN PRINT "Value ", counter, " is OK as value for I2CBusDelay";  ELSE counter = counter + 1
INPUT a$
END SUB
I’m still having the same problems with this device. Can you suggest a solution before I chuck it in the bin;)
My contract ends in Dec 07, so I’d like to get our 8005s working asap.
Doesn’t every function call need paranthesis?
ReadMotor(0), ReadMotor(15)
I don’t work in VB6, but i’ve seen other posts where omitting the paranthesis caused problems.
The software will only run till Windows 98, higher versions of Windows doesn’t allow ‘direct I/O access’. Maybe this is your problem ?
Thanks. I will try this.
Regards,
Kris.
